Coleevans321
- Dec 20, 2020
- 4
- 18
Is it possible to bypass the accelerator pump mounted on the carburetor on this model?
Carb is dumping excessive fuel under load when accelerator pump is connected. Runs like a top disconnected but leaks fuel when motor is in shallow water mode.Why would you want to bypass accelerator pump?
