NewToSmallEngines
- May 14, 2019
- 2
Hello Everyone,
Recently purchased a used XT7 mower. Looks in good/ excellent shape. It was sitting in a garage not temp controlled over the Canadian winter. It is having issues starting and staying running. I bought it last weekend, brought it home, cleaned the carb well, can see through all float holes etc, no gunk, added high test gas, oil looks ok but could be changed. Sprayed exterior moving parts with silicone spray and let sit.
I took the top end apart tonight, put the carb and pull cord bolts back on and boom it started! It ran for about 3 strips of my med size yard and died.
I notice now, once warm the carb is wide open and will not close. Seems the autochoke is stuck wide open now as where it was stiffer to push open when cold.
I have read that it could be the autochoke or the float isn't allowing the needle to let gas flow properly.
I'm going to buy a new carburetor and was thinking either new auto choke or adding a primer.
Any ideas or thoughts are greatly appreciated!!!
Paul
Paul
