I have a Ariens 21" push lawnmower with a Kohler Courage XT-6 engine
Just started it for the first time this year - it started on the first pull ok
After running for a few minutes it started to miss and started to emit large volumes of blue smoke
I pulled off the air cleaner and noticed a large amount of oil - probably mixed with gas - inside the air cleaner box and into the carb
It would not start again
Let it sit for a while after cleaning out the air cleaner box and carb throat and it started after a few pulls.
Blue smoke cleared but after a few minutes it started again until it finally shut down
I had drained the carb before putting it away for the winter
If the rings are bad - since it is out of warranty- it probably is not worth fixing I assume
The mower has not had a lot of use and is just over 2 yrs old
Any input appreciated. Thanks
