Kohler courage 21hp leaking oil
robbie
walked into garage and noticed large puddle of oil under mower upon inspection it appears oil is leaking out of carburetor. Only used mower once this season seemed to be running fine when garaged after use. dipstick seems to be completely covered well above level indicator. should I try starting? anything to check for?
