mustang492
- May 19, 2021
- 1
ok first I apologize for this being long but I feel as though the background info may help. as the title says I have a Toro lx425 with a Kohler courage 20. Last year, in an effort to figure out why the mower would run for ten minutes then misfire I replaced a multitude of things. Carburetor, ignition coil, spark plug, fuel lines and filter, even adjusted the valve clearance(it was slightly off from the book but within tolerance). All that and it ended up being carbon on the valves and two boltless of sea foam worked wonders. well I noticed an oil leak this year and assumed that it was the usual valve cover gasket issue that these mowers are known for so the other day I was working it pretty good hauling dirt around the yard in a gorilla cart keeping an eye that I didn't run light on oil. I pulled the cover and the heat shield only to find out that the valve cover was not leaking it was actually coming from under the flywheel(the upper shaft bearing).the engine and frame were covered in oil as the flywheel was flinging it everywhere throughout the day. I shut it off to clean it off again, go to start it and the starter gear comes up, shaft spins, but does not turn the flywheel. I tried at least five times to start it and same thing each time. after taking the starter apart I noticed everything inside was covered in oil so probably no friction. Flash forward to today and I get my Chinese knock off ( I know) from amazon and throw it on and it cranks way faster than the original one. the mower almost starts and puffs a bunch of smoke and pigs out. I figure maybe I don't need the choke cause this thing cranks so fast so I kill the choke and same thing happens. wont fire up and the exhaust smells horrible. I let it sit thinking it was flooded and still would crank over like a champ but not run. It also backfired twice. Never actually ran though. this thing was running two days ago. Its not the carb fuel line or filter or even the plug. can the ignition coil go bad from me cranking the old starter and the flywheel not turning with the starter gear spinning like that? I'm not even sure if the two are connected. if need be i can try to attach a video. thanks
