Hello,
I have a kohler command single in the shop. I think around 17-18 HP. (model # is worn off) It has a mechanical fuel pump mounted to the side of the block, and has a problem with leaking gas into the cylinder. Weve tried two different carburetors. Rebuilt with new needle valve and checked the float for problems. Everything seems fine, and sometimes won't start leaking until a day or 2 after reinstalling carb.
Could the fuel pump be causing excessive pressure against needle valve causing this leak? Or is it just something wrong with the float valve?
