Hello all,
I have a 25 HP Kohler Command CV730 in the shop. I've been through the carb, replaced fuel lines and filter, fuel pump, spark plugs, tested compression (135 on each cylinder) Set RPM's at 3400. It cranks and runs really good until you put a load on the motor. Then it is very weak. When it came in, neither coil was firing. I happened to have a Kohler 7000 series 25 hp on the floor that had ran out of oil with only 50 hours on the motor. I decided to take it apart to see if the coils were the same. Well, the part # on the coils was different, but they had the same bolt spacing. I put them on it and they both fire and the engine runs.
My question is, could there be a difference in these coils causing the low power problem? I'm beginning to think the timing may be slightly off due to variances in the coils???? Never heard of that, but can't figure out why this motor is weak. It doesn't smoke or anything unusual, just low on power.
Any advice greatly appreciated. Thanks
