hey all,
I have a kohler command 23 in an agco 1823 rider that has me quite puzzled. So here's where I'm at so far, mower sat for a couple years obviously wouldn't run off the bad. What I have replaced so far are ignition coils, spark plugs, fuel pump, carburetor and some random mice chewed wires here and there. Compression tester shows 180 give or take a few on each cylinder. With a spark tester I have good spark and am getting good fuel into cylinders. All that said when trying to start, it will hit like it wants to start but never actually will take off so I'm at a bit of a loss any help would be appreciated. Also using starting spray produces the same results. Chugs and chugs like it is going to start but but never actually starts.
