I tried replacing the coil with a parts tractor (same engine). Still does the same thing. It started last week when i first got it out of winter storage. it ran fine for about 45 minutes, started popping and backfiring then ultimately stalled. Quick spark check showed no spark, but it returned after it sat for about 15 minutes. Then it ran until I finished the rest of the yard, another hour or so. Did it again when i went to mow this week, but this time it won't stay running for more than a couple minutes at a time until it cools down. I immediately thought "bad coil". Swapped it out with another that came from a good running engine and changed the little black box (rectifier?) that has 3 wires running to the coil plus two others (white and white w/ red stripe). Still doing it. What else could it be?
