OzPete
- Sep 3, 2019
- 3
- 13
So, chasing some seriosly in-depth Kohler Tech info here Gentlemen ...
I have here an 2008 build Kohler Command V-Twin, Model CH740S-0095. Serial No.3724211771.
WHAT PART NUMBER DO I USE TO ORDER TO REPLACE BOTH THE IGNITION COILS ???
So "Why", you may ask.
Long story short ... A new to me (& frustrated) client brought it in and asked me to fit the 25 707 03-S Ignition Module kit that he had in his hand.
He had ordered 2 new ignition coils over the phone from his usual Kohler Dealer. Apparently someone had decided that it needed one or both new coils due to loss of spark after 20 - 30mins of running. Jeezuz I hate other dudes diagnoses !
Anyway, so the instruction sheet that came with the the seemed to indicate that it was correct for a CH740 engine.
Well yes, it fitted. But it didn't work.
NOTE: The engine ran perfectly with the original coils .. absolutely perfectly. Just not all day. Coz yep, as suggested, after 20 odd minutes one coil failed, and she don't run no good no more !!
So with the (I dunno, upgraded, modified, different), two new coils from the 25 707 03-S Ignition Module Kit, she runs even worse.
Please Note: I only want to know about IN DEPTH Ignition System info for these engines !!!
Please don't go on about all aother engine functions, as they've all been checked & confirmed. The engine and it's fuel system etc is ALL
in EXCELLENT condition.
Thanks Fellas.
Pete
Thanks Fellas.
Pete
