Kohler carburetor and governor help
ole20
I rebuilt my carburetor and now it will not run unless the choke is pulled 3/4 out.
Also, is there a way to verify that the internal governor is working as it should.
This machine has 1900. hours on it.
Ole
Ariens Model # 931037, Serial # 000365
Kohler, Family #SKH624U1G2RA, M # CH22QS, SPEC # 66534
Serial # 2607121907
Can you hear the fuel solenoid click when you turn the key on and off.
ole20
Hello,
It was not the fuel solenoid, I reset the float and now its running, Still needs work
but now I can at least cut the lawn. Also need to reset / relocate throttle and choke cables, any help here would be great.
Is there a way to test / check internal choke systems without engine disassembly?
