walker1997
- Jul 31, 2012
- 3
- 6
Just purchased a Scag Tiger Cat with 27hp Kohler command pro with 34 hours, when the engine is at idle it sounds like it rattles almost like a shield is loose when you up rpms to mow it goes away. I have had all Kawasakis before is this the nature of these, don't know what this means if you just block off any of the exhaust it goes away. Does this sound like an issue.
