I just worked on one like this yesterday, and from what I can see, you need to move the throttle up one hole (on the same lever it is on), and eliminate the choke cable altogether. That looks like the type that turns the choke on by simply moving the throttle forward all the way. In other words, push throttle all the way forward to choke, then pull back the throttle 1/4 of its travel after it starts for full throttle without choke. Your old motor had the throttle and choke on different controls, this one requires only one.
The reason you need to move the throttle up a hole is so that you get more response with less travel of the control lever. It has to reach full throttle by 3/4 of the throw.
To adjust your cable, loosen the clamp, move your throttle control all the way up, and slide the cable forward until the choke butterfly is all the way closed, then tighten the clamp. The issue I had to fix yesterday was that the cable wasn't adjusted right, and the choke wouldn't close enough for the customer to get it started without priming it.
