drfrideres
- Aug 15, 2014
- 2
- 10
Hi all,
I'm looking for some direction on my Kohler 18 v twin. It has a manual choke, will fire, and once I put the choke off will not continue to run. Almost seems as though it is flooding. The engine doesn't run more than 2-3 seconds so a total of about three or four cylinder fires I'm thinking. If I continue to crank the engine I'll smell gas shortly. If I let it sit for a while it will do the same thing, fire a few times then quit. I pulled the air filter to check the choke valve to make sure it was operating.
So I can't figure if it is the gas or the spark, but it seems it shouldn't be a spark problem if the engine fires. I've looked everywhere on the web but haven't found an answer that fits this question. I'm hoping someone might be able to help.
On a side note, I had just replaced the plugs, filters, and tuned the jet on the engine since it had been a while and the engine was running slightly erratic on idle. I had started it three times after and mowed flawlessly and ran flawless.
