I was using my KM55R Kombi unit and while running, the motor stopped as if I had shut the switch off. It was running perfectly until that point. Since then I have tried everything.
New Ignition module
New Switch
New Spark Arrestor
Brand New Stihl Carb
Compression is 100lbs
No scoring on cylinder walls
It has spark, it has fuel and it will not fire. The fact it was running perfectly and just shut off has me wondering what happened. It wasn't running rough or hard to start, it just turned off.
Any suggestions would be appreciated, thank you.
New Ignition module
New Switch
New Spark Arrestor
