Im trying to fix an issue with this Husqvarna 54" riding mower with the Kholer Courage 25HP Vtwin
Symptoms
This is what i have replaced already
Any suggestions on where could i go from here?
Hi everyone,
I'm trying to diagnose a persistent issue with my Husqvarna 54" riding mower and could use some guidance.
Symptoms:
What I’ve Tried (using parts from a known-good identical engine I have):
Any suggestions on what to check next would be greatly appreciated!
Symptoms
- Mower starts just fine and sounds perfect when starting cold
- I can engage the deck and mow grass for about 15 minutes without an issue
- After 15 mins and specially under heavy load the engine starts to surge and eventually stalls
- If i catch it early enough when it starts surging an I disengage the deck and reduce the throttle, it sometimes avoids stalling, and if i leave it like that for like 2 mins, I can set everything back to normal, re-engage the deck and it will mow for a few more mins before surging/stalling again
- Carb
- Airbox with filter (the one that sits in front of the carb)
- Fuel filter
- Fuel pump
- Coils
- Sparkplugs
Hi everyone,
Symptoms:
- Starts and runs perfectly when cold
- I can mow for about 15 minutes with no issues
- After 15 minutes and when under load, the engine begins to surge and eventually stalls
- If I catch the surge early, I can sometimes prevent stalling by disengaging the deck and lowering the throttle. After idling for ~2 minutes, it will run normally again for a few more minutes before repeating the same symptoms
- Noticed this mower runs significantly hotter than an identical unit I own—might be unrelated, but worth mentioning
- Replaced:
- Carburetor
- Airbox w/ filter
- Fuel filter
- Fuel pump
- After exhausting fuel-related suspects, I moved on to:
- Ignition coils
- Spark plugs
