Keeping the Tires Rolling
Rev ME
Greetings Everyone.
This is my initial post, and I would like to ask a question: What is the recommended tire pressure for a Cub Cadet RTZ 54?
I looked at the owners manual that came with the mower, and have looked on other sites, that say to see the owners manual.
I also have an RTZ 42, and I've been using 12 psi in the rear tires and ~ 30 PSI in the front, to prevent the tires from leaking on the beads.
I look forward to any spec's or recommendations.
Best Regards!
:welcome:
Welcome to the forum!
I'm going to move this thread over to our Cub Cadet section to see if we can find you an answer.
I run less than 10 psi in my rears on my M60 tank but I make sure both the left and right tires have the SAME pressure. On the front's, 30 psi, same again on both sides. The softer the rear tires are, the better the ride. I just run enough so they don't come off the rims and no more.
