Keeping It Green
Green Girl
I have long wanted a green house so I could winter over different plants and get some plant starts going earlier in the spring-----the growing season in the northern Rockies tends to be short. This winter I'm going to research the options. Any design suggestions??
Rocky
A simple solution for you might be to invest in one of those portable greenhouses. It sets up kind of like a tent. I've had one for about four years now. It's great because I can take it down when I don't need it.
Twinkle
It's a great idea and the kind of thing you will wonder how you managed without. My hubby reckons the greenhouse is a close second to the shed when you want to escape and ponder nature. If you have small children or anyone playing ball games in the area I really recommend avoiding those made with glass!
adan
There are greenhouse designs available in the internet. Just Google the words "greenhouse designs." I suggest you start with the simplest of designs, which are portable in nature. As you progress, move on to more permanent structures. I'm from a tropical country though, so I don't know how you define "simple" over there where snow can create a load over the structure. An agricultural or civil engineer in your area would know.
grnspot110
I just use mine to start seedlings in the Spring with little or no heat. Simple "hoop" design (10'x10') with solid north end (w/door). Two-layer inflated plastic cover. I have to replace the outside layer every couple of years. 4"x6" treated sills with one 4"x4"post on the south end, two posts on the north, 2"x8' treated ridge board, 20' 1" schedule "40" pvc pipe hoops. Has worked well for many years for me~ ~~ grnspot110
touree
Green houses are a really good idea and like the op has said, get the portable one for your own convenience. You will like everything about your experience.
Driller
I think it's an awesome idea, but I've never actually had one so can't give out much advice. I hope you'll keep us updated, though. Pictures would be great!
bret
Looks really cool. I just got myself a real good deal on a greenhouse in the summer, I can't wait to try it out next spring, my green thumb is just waiting.
Twinkle
These look realy nice and it's great you don't need to heat them. Is that because of your climate or the way they are made? I wonder if it would be okay to add heat if necessary.
grnspot110
It's just the time of year when I start my seeds! I do occasionally use electric heaters for a late cold snap. ~~ grnspot110
