Kawasaki fs541v powered Torro Grandstand spluttering
Tribaldude
Hi Guys.I have a Torro Grandstand 41" with a Kawasaki fs541v petrol engine.I have changed plugs to bpr5es (ngk) as online shows is correct.
It runs smooth and fine for approximate 25min and then picks up a splutter as if not running on both cillinders.I have checked the choke shaft that sticks sometimes ..its a mission removing the carburetor but i have done that and cleaned it ,i thought maybe the previus plugs being a bp6es was not hot enough.im a rookie and will appreciate any advice,,Greetings from South Africa.
Ps..the hour meter smart module was not working so i bridged it out
