i have a kawasaki FR600V-AS05 engine on a exmark lazer z turn zero, it starts and runs (in idle high and low) fine but when i start to move it bogs down. I checked for sparks and both cylinders/coils have spark. Here is what has me confused. I pulled the spark plug wire on the left side (by fuel pump )and mower runs just fine, put that back and pull the the wire on the right (by the oil filter) and mower dies. figured maybe a bad coil (even thought i have good spark on both), so i switched the coils and same results. Im very confused, i figured it should run if i pulled either spark plug wire just that it would run rough. I even switched the spark plugs around just in case but same results. Pull the wire on the left runs fine (until mower is put under a load by either driving it or engaging the blades) pull the spark plug wire on the right mower dies. Another thing that it is doing (not sure if related to problem but figure i mention it) is that sometimes when i turn the key on mower off the mower keeps running. i figure the coils are good, but not sure where to go from here, REGULATOR-VOLTAGE? COIL-CHARGING? mower was running just fine about a month ago when i last used it. Any suggestion as to what might cause the engine to die when i pull the
