Hi
I have a husqvarna pf21awd ride on mower with the Kawasaki FH641V engine.
The problem I have is that it will run for about an hour it then starts to hunt. I shut the mower down and check all the levels (oil etc). When this happens I find petrol in the oil sump and a mixture of oil and petrol in the air filter housing.
I have stripped the carb twice, using ultrasonic cleaner and replaced float needle and o rings and gaskets twice. It is still a problem anyone have any ideas what might be wrong? The machine has only done 250 hours so has not been used much.
