Hi guys,
New to this stuff. Hope you can help.
I have a 15 year old Ferris hydrowalk commercial mower. It has been a very good mower. Well maintained.
Lately it stalls when leaning hard to the left. Going straight up a hill or leaning to the right it's been fine.
Today it stalled and would not restart. I pushed the mower around so it was leaning to the right and it restarted.
I've replaced the fuel pump, fuel filter and carb. I've also replaced the two coils and spark plugs last fall. I just re-adjusted the spacing on and cleaned the coils to no avail. I also replaced the breather last fall as well. Changed the oil and filter ( it needed it, not because I thought it would help).
The hydrostatic drive oil is dirty, but I can't see that doing anything to stall the motor., but I really don't know. I ran it today for twenty minutes at full throttle; no problem.
Did have a stuck valve last fall which bend a lifter. All was cleaned and changed. Ran fine all year. This issue started three weeks ago. Help, I'm out of ideas.
Thanks guys!
Thanks guys!
