Kawasaki FD791D Ignition Coil Replacement
John Ambrosia
My Scag Turf Tiger, with a Kawasaki FD791D engine, needs a new ignition coil. I plan to replace both coils and it looks like the radiator needs to be removed to do this. I’ve never done this before and would appreciate any tips anyone can offer before beginning this project. Thanks in advance.
Go through this manual first and make yourself aware of what you will run into before starting. Depending on your experience this is not as simple as it sounds with this engine. When doing this I normally set aside 4 hours and like to have an assistant available for the third, fourth and fifth hand, plus extra set of eyes. First time doing this, have camera available and take more pictures than you will ever use. https://www.mymowerparts.com/pdf/Ka...FD791D-DFI-KAWASAKI-SERVICE-REPAIR-MANUAL.pdf
John Ambrosia
Sounds a bit ominous! Forewarned is forearmed. Thanks for the info. Much appreciated.
