- May 6, 2010
- 45
- 11,133
I have this engine on a Scag that is runnng poorly. New NGK BPR2ES plugs. Been through the carb. Adjusted valves to factory spec. Compression on both cylnders is around 110. Will not start hot or cold without choke. Popping back through the intake intermittent on both carb barrels. Throttle shaft and linkage holes are worn and the carb and some of the intake gaskets are either hard to find or NLA.
If you apply almost full choke will smooth out and the rpm's increase greatly. But if you spray brake cleaner or dribble gas into the intake immediately goes rich. And engine will not idle and engine doesn't surge. Check spark on both cylinders using 2 different spark checkers, and spark doesn't appear to be dropping out.
And the engine has 1800 hours according to the hour meter on the Scag.
