The motor is missing and worse under load. I ran it briefly, checked the plugs, and one was hotter than the other. I swapped the plugs and both were firing off of one side but not the other so thought it was the coil and replaced it. Still having trouble so bought new plugs. Looks like equal spark on both sides but spark is weak. The voltage wire going from the regulator is the same for both coils. It cascades or chains to the first coil then around the engine to the second coil. Anyone know what voltage I should find going to these coils?
