This motor is in a gravely 260z. 3oo hrs, 2 yrs old, been having a lot of issues with losing a cylinder while operating, do to, what I believe, is a carburetor issue.
Here is my story
1st event
owner has lack of power...guy takes carb off hits with some cleaner, back on his way...........few days latter it's back in, I check it out, its dropping a cylinder and back firing on occasion,, idles great.
Checked ignition, all seems good. So I pull carb again' knowing that helped before and see it has a separate venture for each cylinder. I haven't seen this before but that's fine. Clean carb overnight, reassemble, runs great for 4-5 days. Again dropping a cylinder on occasion. Add another fuel filter, new line to carb, gaskets, and runs great for a period of time and then seems to repeat itself. I've had it apart 4 times now, haven't seen it back yet but I fear it's coming.
Does anyone know if there's a cure for such a beast!
Thanks
Biggsee
Here is my story
1st event
Thanks
Biggsee
