Kawasaki FD501 won't start
RandyO
John Deere LX 279 with a Kawasaki FD501 engine will not start. Both plugs have a spark, it's getting fuel and both cylinders have 160 psi of compression. It backfires when I try to start it.
dfbroxy
Adjust the valves
EngineMan
Also the flywheel key.....maybe timing out...
RandyO
Thanks, I'll adjust the valves and if that doesn't do it I'll take a look at the flywheel.
