Engine won't start when hot. Kawasaki FH721V-AS32 Looking for any ideas on where to go, compression is 150.
One possibility is the coils. Do you have spark?
Can you hear the fuel solenoid click when you turn the key to ignition only? (not to start) After you run it, the little solenoid coil may be failing enough to not open the fuel shutoff. gregjo1948
I am having the same exact problem. Was told its the carburetor. Lot of money to be guessing? Any for sures out there. Once it's running it sound great . Throttle it up quick and it back fires big. Greg
