gatorblade
- Apr 16, 2012
- 10
- 52
I have an 02 Hustler z 60" 23hp Kawasaki with 450 hrs. At idle, it speeds up then slows down. At mowing speed it does the same but is not as noticeable. Last fall I replaced the fuel filter, spark plug and cleaned the air filter with no improvement. It's worse this spring, as it will die if throttled all the way back. In storage I just add stabil to the gas each year. It has the original battery! Any ideas?
Thanks gatorblade
Thanks gatorblade
