gatorblade
- Apr 16, 2012
- 10
- 52
Working on our 2002 Hustlerz 60". Idles up/dwn, not as noticeable at full throttle. Sonofadocker suggested manifold leaks,cracks in gas lines. Took carb off checked out ok. Is there a carb parts blow up available somewhere. I would like to check out the float bowl,and jets . There were two bolts on bottom of carb with the # 5 stamped on them . Two brass bb's were imbedded by each bolt. Couldn't break loose the bolts. I need to know what they are before I put more effort in them.
Thanks Gatorblade
Thanks Gatorblade
