I have a 22hp Kawa that floods trying to start it. I try adjusting the choke, throttle ect. no luck. plugs are new. Also a HIGH amount of black carbon on plugs 10 hours old! i am frustrated. any help would be awesome!!!!
Check to see that your oil is not over filled. I know you said 10 hours old, but check your air filter. make sure it is or has not been wet. Liquid be it water or fuel on a paper element closes the cells and restricts the air flow giving your intake a too rich mixture, which would carbon up your spark plugs.
