Kawasaki 19 hp 601VBS32
Gary1
when i engage the clutch it is like it goes to half power. I have checked the coils on both sides and all of the pulleys and spindles and can't find a reason for the loss of power. Any suggetions would be greatly appreciated. thanks Gary1
Fuzzy1
Try putting a meter across the leads where the PTO plugs in ... check for a voltage drop when the PTO is engaged.
Charging circuit may be weak .. or PTO can be pulling too much power.
