jx75 john deere carburetor
leno
I've had the lawnmower since 2002. This year (2013) after mowing for 20 to 30 minutes the engine will start to die. It gets down to a idle and then starts up to full throttle again. It does this several times and then finally will die. If I let it cool for about 1/2 hour and start it again, the routine will repeat. It seems to be heat related.
Doesn't sound heat related to me. More likely a lack of fuel. First thing to try is easy, next time it starts acting up, loosen the gas cap. If the engine returns to proper running, your cap has a clogged vent and I recommend replacing it. If that does not fix it, I recommend removing the carb, give it a good cleaning and when you reassemble, make sure that your install a new float needle and seat.
