Hello;
I have been gifted a John Deere GXJS63D111073 mower that needs both cables that run from the right hand side of the handle to the transmission. I sense the Transmission Cable which has the spring on the end is part # GC90045, and the Traction Control Cable which has the 3 speed selector, is part #GC00153.
Two questions: Are these correct, and if so, can I only purchase these through a John Deere dealer?
Thank you!
Thank you!
