Hello,
I have a JS30 that from time to time bogs down on me and sits there just barely running. It takes a pretty good amount of time for it to spool back up to full speed. When it first happened I raised the deck and sharpened the blade and subsequent mowing's had it happen only 2 or 3 times. Last time mowing though the grass was somewhat moist and it bogged down probably 12 times and each time it took 1-3 minutes to get back to full speed. If I release the handle and let it shut off and start it again it will start in the same bogged down state. There's no buildup of clippings underneath and nothing spits out when it finally does spool back up.
Any ideas?
Any ideas?
