OldGeyser69
- Jun 18, 2022
- 1
- 2
Calling all D105 FanBoys(& Girls), actually anyone with knowledge of this "TOP OF THE LINE" \ Exquisite \ Prestigious, John Deere offering
Ok!, I might have said too much . . .
Yes! Taryl, the POS with the plastic transmission. [Taryl Fixes All]
Since >20K units(Recall Amount) were produced, -- it is likely someone else has encountered my exact scenario.
I am trying NOT to Re-Invent the wheel here, So any help gratefully appreciated.
Here Goes:-
I was pulling a detacher loaded with a couple of cinder blocks with my D105.
Then i became aware of somewhat horrible sound.
It sounded like a bucket of nuts, rotating inside a washing machine.
For sure it sounded like a bad bearing somewhere.
I stopped and checked the engine dipstick for oil level, i did notice there were little bubbles on the dipstick.
Because the engine was hot and not settled it was difficult to read the actual oil level, on the stick. --i put some oil in as a precaution and proceeded to finish the yard
I noticed that even a small touch down on the “BRAKE” pedal caused the noise to disappear !!, HMmmmm ??.
It was only when the brake pedal was fully released and the machine was in motion that the obnoxious sound could be heard.
I found a part's diagram and also found some information on the internet, which led me to suspect one or both of the 2 idler pulleys, #9 & #11 on this Parts Diagram
https://partscatalog.deere.com/jdrc/sidebyside/equipment/65843/referrer/navigation/pgId/77560047
My JD Store had both and was only a half hour away if indeed i did need them.
I figured this was a straightforward and a simple fix. I took down the deck, and pulled the 1st pulley.
To my total surprise it was perfect, i thought ok it's got to be a second pulley,
which i then removed and again low on behold it was also perfect.
From what i could see of the belt also looked to be in real good shape.
Got to admit i was baffled, with the aid of an accomplice sitting on the seat to prevent the tractor from stalling out, i stuck my cellphone underneath and hoped to catch some video of what was going on down there.
Have a look at this short video link [~20Secs]and see for yourself.
https://drive.google.com/file/d/12wgfgXHZNcofil49OkZSFW4YlHpPDy57/view?
The belt to me looks real “Loosey Goosey” but perhaps that’s the modus operandi, for this setup.
I am reluctant to blame the belt as 2 years ago, i went down a rabbit hole, with what i thought was a loose mower “DECK” belt, only to find that the new mower deck belt behaved in the exact same manner. -- See this picture.
https://drive.google.com/file/d/1u_FA4Izz6aLrV3u79DqY79Vz88QGQsqj/view?
Never did get to solve that one.
More IMPORTANT . . .
Regarding my present “DRIVE” belt problem
perhaps someone with a similar model might have experienced this same issue.
I would like to get some ideas before, i tear it down again.
Someone, owning a "D105" might have encountered this FLOPPY BELT \ NOISY issue, & might save me the trouble of multiple tear downs, to try track this issue.
Anyway!
Thanks All
OldGeyser69
Here Goes:-
Anyway!
Thanks All
OldGeyser69
