Have had MANY issues as you guys have seen in my recent posts and I want to really thank k you guys for the support and help. The NEW ignition switch was faulty. Kept on reading and reading and following through with the technical manual and decided what the heck. Tested it and bam nothing. Made a 2 hour drive and swapped it out. Just the ignition switch alone solved all of the safety switch issues with the brake and handles. You cannot bypass an ignition switch without the mower correcting you and saying nope.... fix it right like bertsmobile1. Thanks bert
