John deere z225 died while mowing cant get it started
Poncho1
  • / John deere z225 died while mowing cant get it started
I was mowing and mower died and won't start I've check everything I know to check ,getting fire to plug, checked fusses reset value, cause motor wouldnt crank thought it had locked up.found a wire cut it come out of square box that's attached to the oil tube and has 3 wires 1 light brown 1 yellow 1black both blk. yellow are hooked up ,don't know where it, brown goes anyone help please been trying all night ready to blow it up . Just kidding
Hammermechanicman
Is it a Kohler engine? Sounds like the wires from the ASAM module to the ignition coil.
