John Deere X540 Motor Wire Harness Yellow Wire
Ru4him
Where does the yellow wire from the motor harness go to. It has the round end with a hole. It looks like it might go to the solenoid, but could be a ground. Does anyone have the wiring schematic for this mower? Thanks for helping me out.
If wire 500A or 500B yellow wire. X6 cconnector. Basically it is for the headlamps. X2 does not show any yellow wires.
Just not you must the printed number on the wire as JD is bad about changing wire colors but they keep the same number.
