megawattkid
- Apr 18, 2013
- 1
- 1
My JD x495 PTO will not engage. I checked the PTO solenoid and it's not getting any juice with the pto switch on, engine running, etc. If i run 12 volts directly to the solenoid the pto kicks on. I've replaced the pto switch, the RIO switch and still no power to the solenoid. I've checked the seat switch and even jumper'd it out, still no power to the solenoid. I've checked the grounds that I know of and the fuses. All are good. Does anyone have a wiring diagram for this mower or suggestions of what may be causing it.
