John Deere X360 loses power
cooker1110
I noticed when snow blower was on that it seemed to loose power after abt 1/2 hr. of running. I now have the Mower deck on and it is doing the same thing. When I disengage the mower tractor runs fine. Any thoughts? I changed fuel filter and does same.
Mikel1
So with mower disengaged you can run past the time given above with no lose of power?
cooker1110
Yep I ran tractor around yard and ran fine. Only does this when under load.
Mikel1
What are your engine #'s? When it is starts losing power try pushing throttle control to choke and see if there's any difference.
