John Deere X350 vs Cub Cadet XT2
Mower Man Dan
So I am doing my homework on purchasing a new rider, looking more for a buy once, cry once option. I will be mowing half an acre, pretty flat residential lot. Currently using a 20 year old Craftsman lawn tractor with a 24 hp Briggs v twin with hydrostatic transmission and 42" cut. 42" cut is as big as will go through the back gate. Want a tractor as I occasionally move wood around with a pull cart.
As I see it, here are the key differences between the two tractors:
JD has Kawasaki engine, the Cub has a Kohler 7000 series. Both seem highly regarded
JD has a stamped deck. Cub is fabricated. Advantage there goes to the Cub, if I'm not mistaken.
JD has a 4 year, 300 hour warranty. Cub is 3 year unlimited.
JD has electric PTO, Cub is manual. I strongly prefer electric
Both have the k46 hydrostat.
The Cub has a single support rod at the front of the deck. The John Deere has two. Seems a bit odd you would go to the trouble of putting a heavier fabricated deck on the Cub boasting about 11 gauge steel and then put half the supports on it on the front?
The Cub is about $800-$900 less. But I'm open to discussion about these or any other options. Thanks in advance for reading and any input!
Craftsman Garage
With half an acre, you'll probably hit the 4 year mark before 300 hours, so the JD warranty takes the win there. Kawasaki is often regarded as the "gold standard" for the best air-cooled engines. I really love them. Manual PTO could have it's fair advantages only that there are less parts that could go bad. I wouldn't worry too much about the deck supports, JD most likely has 2 to prevent the stamped deck from flexing and to maintain a consistent deck height while mowing. The JD frame is also built heavier and better than the cub. I have a Kohler 7000 series, and had a Kawasaki FR691v (wish I hadn't sold it), and the 7000 series can be finicky to work on, and they are definitely not built as good as the Kawasaki. I say go with the John Deere.
Mower Man Dan
As I dig further and look to the long term, there are some things I am liking better about the CC. Parts appear to be less expensive. And when I stopped in at my local dealer, he stressed to me the level of service they provide for people who bought their mowers there. He mentioned that if there was ever a warranty repair needed, they would pick up the mower and deliver it back free the first time. The JD dealer emphasized there would he a charge every time. The CC dealer also said if the mower was ever in for any amount of time during mowing season they would provide a loaner mower free. The JD rep never mentioned that so not sure what they do. I feel like the Kohler engine will live a fairly easy life doing a flat half acre and getting about 30 hours a year. Couple all of this with the $900 savings on the initial cost, I am heavily favoring the CC. The heavier frame and Kawasaki on the JD are enticing for sure. Just not sure if it may not he overkill for my needs?
Craftsman Garage
That $900 difference is the difference between the Kohler running maybe 800 hours or more, and the Kawasaki which are known to easily get more than 1000 hours. As you say, Buy once, cry once, I just don't see that with the cub cadet.
Mower Man Dan
800 hours of use is over 26 seasons for me. Won't robot butlers be cutting our lawns by then? 😆
Also, that $900 savings invested in the market at 7% would be over $5k by the time the Kohlers done, assuming an 800 hour life! That would probably buy me a push mower in the year 2052.
Chuter
I'm not convinced the fabricated deck is better than the stamped deck. I know it's been debated without any clear winner. I've got a fabbed deck on my Simplicity, and it's heavier than ten dead pigs. I hate removing it to sharpen blades or anything else. and I suspect it lifts less to give me less clearance in my gravel driveway. I've also found the stamped decks to stay much cleaner (on the underside) since the airflow is built into them - they don't have the sharp corners that trap grass. The fabbed deck is better if you hit stuff with it, and maybe will take longer to rust through, but if you leave a buildup of wet grass in it, you'll probably end up in the same place. Just my $.02. Truth be told, pick the one you like, take care of it, it will probably last you a long time.
