John Deere X340 lawn tractor won't start
woodywoody
Here's the scenario.
1) I'm mowing.
2) It starts drizzling, and then stops
3) I decide to wash the mower (It's never been washed for 10 years). I hosed it down and brushed it with a gentle brush.
4) The drizzle stopped and the grass was still rather dry
5) I'm mowing for about a half hour long and dropped my phone
6) I turn the mower off, retrieve my phone, get back on
7) I won't start. I mean, it won't even crank
8) Since this problem just appeared I started with the notion that the seat switch (shuts down the mower if you get off it) was the culprit
9) I connect and re-connect the plug. Still no start.
10) I short the two sockets where the seat switch plugs in with a wire to check if the seat switch has gone bad
11) Still no fix.
12) I try to push it back to the garage where I can work on it but the wheels are locked like the transmission is still engaged.
13) Now it starts raining and I have to leave it in the rain and come in research what's going on.
14) The forward and backward pedals also seemed to be mushy. Maybe wet grass got up in there and gummed up the works?
Any ideas?
Did you make sure that the PTO switch is in the off position? Here a troubleshooting procedure which might help you out.
Electrical problems can be very easy or very difficult, depending on four things.
1. How well you understand basic electricity.
2. What tools you have and know how to use.
3. How well you follow directions.
4. You don't overlook or assume anything and verify everything.
Remember we cannot see what you are doing. You are our eyes, ears and fingers in solving this problem. You must be as accurate as you can when you report back. The two basic tools we will ask you to use are a test light and a multi-meter. If you have an assistant when going through these tests it would be very helpful. These steps work the best when done in order, so please don't jump around. Now let's solve this problem.
First, check the fuse(s), check battery connections for corrosion (clean if necessary) and voltage - above 12.5 volts should be good. Check and make sure the chassis ground is clean and tight.
Second, check for power from the battery to one of the large terminals on the solenoid. One of the wires is connected directly to the battery and has power all the time so one of the large terminals should light a test light or show 12 volts on a meter at all times.
Third, check for power at the small terminal of the solenoid while depressing the clutch/brake pedal and holding the key in the start position (you may need an assistant to sit in the seat to override the safety switch). If your solenoid is a four wire solenoid, check both small wire terminals as one is ground and the other is power from the ignition switch. If your solenoid is a three wire solenoid, make sure the solenoid body is not corroded where it bolts to the chassis of the mower as this is your ground path back to the battery. If in doubt, remove the solenoid and clean the mounting area down to bare metal. If there is no power to the small terminal then your problem is most likely a safety switch, ignition switch or in the wiring.
Fourth, check for power on the other large terminal of the solenoid while holding the key in the start position (you may need an assistant to sit in the seat to override the safety switch).
Fifth, check for power at the starter while holding the key in the start position (assistant again).
Sixth, check your ground circuit back to the battery.
After you have gone through each of the above steps, let us know what happened when you did each step. At that point we will have great info to tell you how to proceed. Remember you are our eyes, ears, and fingers, so please be as accurate as possible.
Be as specific as possible with voltage readings as this will help diagnose your problem quicker. If you do not know how to perform the above checks, just ask and I will try to guide you through it. Youtube also has some videos and as you know a picture is worth a thousand words.
woodywoody
Voltage of battery is 11 volts (I put the meter electrodes on each battery terminal directly) That's really low but I'd at least expect the solenoid to click.
I sure didn't expect that. I'd been mowing for an hour. It should have charged. It might be bad because I left it out all winter and it got exposed to subzero temperatures.
I'll slap the charger on it and see if that fixes it enough to start and move the mower into the garage.
The fuses are all not-blown.
