John Deere x304 barely moves belt slipping
Dayshaw
My first post so patience and nay help is greatly appreciated!
John Deere x304 barely moves, with the engine running (starts great) drive belt and transmission fan appears to run fine until you engage, you get a slight forward or reverse movement then the transmission fan stops moving and the belt appears to be slipping.
Installed a new drive belt today and there is about 10 hours on the flat and v idler.
Thanks in advance
Dayshaw
