John Deere x165 Engine loses power when engaging deck
Snitz999
  • / John Deere x165 Engine loses power when engaging deck
HI Guys
I have a John deere x165 . Actually we have 2 . One is perfect .The other one has been to John deere South Africa and more than i can count lawn mower service people .
It loses intermittent power when engaging the deck . Sometimes it will run for two hours without a hitch . Then al of a sudden it starts losing power when belt is engaged
regards
Kobus
Idler pulley or spindle bearing freezing up possibly.
Snitz999
Just climb on the tractor and mowed with no problem for a half and hour .so its a problem thats there and then not .
Jack17
I'd say check the fuel filter and gas tank air vent. Sounds like something is pulling a bit of a vacuum on fuel delivery system.
Snitz999
Think i found the problem .one spark coil is dead so engine running on one cylinder .
That would do it.
