I have a 1996 STX 38 black deck lawn tractor with a Kohler Command 13 engine. I got the mower for free from a guy who thought the engine was bad (actually, he quietly told me that he didn't think it was too bad, but it made a funny noise while his wife was mowing. They had a lot to mow, so he wanted to buy a bigger and more comfortable mower so his wife would continue mowing). Turns out the butterfly plate in the carb came off. Reinstalled that, plus a new belt and sharp blades, and it has worked and run great for about 4 years now.
However, when I changed the oil last week, I noticed the engine was over full and the oil was thin and smelled like gas. Is there anything besides the carb that would cause this? When I remove the air filter I can see a small pool of gas straight down below the filter. Plus, the tractor will backfire occasionally when I shut it down.
I did have a little trouble starting the mower this year, so I cranked it over quite a bit before buying a new plug. Started right up after that. Don't know if all the cranking might have dumped gas into the oil, but I think it was already in there.
Thanks for any help or ideas.
