John Deere R 72 ? on mower deck spring
aljoy
Have a John Deere R72 I would like to know where the Mower Deck Spring goes ,( Spring is about 5" with a hook on each end), and what does it hook to. Any help is most appreciated. Thank you
BlazNT
We need to know Model and Serial numbers to get the correct image for your deck. I did a Google image search for "John Deere R72 parts diagram" and got hundreds of different images for decks.
aljoy
I have this number MOOR 72X 321730
also have 1907075830-01 84120309 8hp
BlazNT
aljoy
Here is an explode view. Hope it helps.View attachment 22556
On my deck I do not see the opening for the cotter key to hook the spring to , also
If the hook fastens on the deck where does the top hook , hook to., I must be missing something,
BlazNT
Ok the spring is there to create tension for the deck belt so the blade will spin. it looks as though it connects to part #21. I am not sure of this but from the picture that is where I would start looking. Whole in deck could be plugged with grass or dirt. Just poke around a little with a screwdriver and see if you can find it.
aljoy
Thank you soooo much for your help, it is very much appreciated
