will only run with choke on
E ed ibex Forum Newbie Joined May 7, 2015 Threads 1 Messages 1 May 7, 2015 / john deere lx277 #1 will only run with choke on
I ILENGINE Lawn Royalty Joined May 6, 2010 Threads 43 Messages 10,737 May 7, 2015 / john deere lx277 #2 Either the fuel solenoid on the carb isn't working or you have a jet clogged up inside the carb. If the solenoid clicks when the key is turned on, then remove the carb, and clean all the passages
