John Deere LX173 Starting problems
kosmok1000
Sometimes starts up and run fine other times wont start and backfires.
can someone help please
webuyanymower.com
Hi
Sounds like dirt in the fuel. Check everything from the fuel tank through to the carb clean the carb and change the fuel filter.
Then check the can you keep the fuel in make sure it is clean
taxidermist
Might need the valves lashed.
Rob
kosmok1000
I replace the fuel twice, it runs fine some times if starts right away, but if turns more then 3 times wont start and backfires about every 30 seconds, I have to let it cool before trying again.
reddragon
backfiring is usually a lean symptom...caused by fuel starvation....your carb may need a good cleaning....check your fuel filter too:smile:
SONOFADOCKER
At our shop we find everything in fuel tanks and lines . Little kids will put anything in there ... Very commons is grass clippings and spiders . Use a small Compressor and blow air away from the engine towards the tank . Start at the tank side of your fuel filter . Be surprised what could cause a partial block and see what floats in the tank ... Clean the gas cap too . Ethanol is now distorting gas caps and the cap insert that is supposed to let air in as the fuel is pulled towards the engine.
