christophert
- Aug 1, 2017
- 15
- 37
I have a question, we have a LX277 in our shop with a Kawasaki engine. It was dropped off with the complaint it would only run at 1/2 throttle amd it would break the deck springs. We pulled the engine and inspected the governor and it appeared ok. But, when we reassembled the engine and restarted it still will only run at 1/2 throttle no matter how we try to adjust the governor. Has anyone else experienced something along this line and if you have was the governor the root cause or should we look somewhere else? Thanks for any help!
